Date/Time: Wed, 25 Dec 2024 17:46:51 +0000
Inconsistent volume study
View Count: 842
[2015-11-30 13:19:25] |
User921987 - Posts: 238 |
What could be the reason for the inconsistent data in the situation where I attach Bid Volume, Ask Volume and Volume studies to my chart (pls see attached pic) ? This is a tick chart where volume says 3 contracts traded but the sum of the bid and ask volume gives 4. Can I really trust the all bid/ask studies in the application if this is possible ? SC is configured to run on Rithmic (AMP Futures). Date Time Of Last Edit: 2015-11-30 13:21:49
volprob.png / V - Attached On 2015-11-30 13:19:04 UTC - Size: 22.42 KB - 296 views |
[2015-11-30 19:27:15] |
We discovered the reason for this problem. It has to do with the time and Sales data that is inserted into the historical data file when transitioning from a historical data download completion to real-time data. This affects a very very very tiny number of records. So you can trust the Bid and Ask Volume. This has been solved in prerelease 1331. You can update with Help >> Download Prerelease. You can also re-download the data in the chart by following these instructions to correct the data: https://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-30 19:27:51
