Date/Time: Wed, 25 Dec 2024 17:37:38 +0000
DOM question
View Count: 711
[2015-11-30 10:29:45] |
EuropeanTrader - Posts: 290 |
Hello, please tell me if it is possible to have certain sound enabled when my orders are being filled in DOM. Also, is there a way to increase the size of buttons BUY SELL MKT JOIN...? Thank you! |
[2015-11-30 10:39:23] |
Yes, refer to the Alert Settings here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#GeneralTradeSettings The size of the Trade Window buttons cannot be changed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
