Date/Time: Wed, 25 Dec 2024 17:26:57 +0000
Extreme sluggishness/Freezing
View Count: 714
[2015-11-30 09:11:18]
Dom7364 - Posts: 257
Good morning,
I have been using a chartbook for some years, which has been working properly. I have not changed or added antyhing new to it, but suddenly, SC has become very unresponsive. Clicking on any menu, or right clicking on a chart, or clicking "Ok", "Apply" and antyhig else takes 10-20s to respond.
I have tried to delete some sheet, one by one, to see if one in particular was the cause of the problem but I can't pinpoint it.
I don't know what else to try but this is unusable as it is.
Thansk for the help.
[2015-11-30 09:21:22]
Refer to help topic 30:
http://www.sierrachart.com/index.php?page=doc/helpdetails30.html
All known reasons for this are documented.
[2015-11-30 09:32:41]
If nothing has changed and it was working fine, why wold it suddenly stop working I wonder?
I have checked this page and can't see any possible reason within the list..Even with all Chartbooks close SC is the highest Memory consummer in Task Manager (489 996K)
Date Time Of Last Edit: 2015-11-30 09:35:19
[2015-11-30 10:10:28]
Start with just one single chart with a minimum of studies and see if you have a problem with that.
You need to start with a simple set up and gradually add to it.
