Date/Time: Wed, 25 Dec 2024 17:58:13 +0000
How can create a ORDER FLOW based candles ?
View Count: 922
[2015-11-30 09:02:40] |
SKY - Posts: 45 |
if ques is unclear - looking to have candles where each candles is constructed of 2 columns presenting the offer / buy contracts executed at each price tnx |
[2015-11-30 09:22:27] |
You need to use the Numbers Bars study: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
