Date/Time: Wed, 25 Dec 2024 18:03:57 +0000
VbP POC and VA extension lines
View Count: 797
[2015-11-29 03:17:40] |
User400641 - Posts: 2 |
The Extend Point of Control and Extend Value Area selection of "Until Future Intersection" works correctly on the TPO chart. My corresponding VbP study (based on the said TPO chart) will not support the same selection even though it is offered. The "End of Period" and "End of Window" work correctly. I have utilized the settings guide from the website to make sure I have the settings correct for the study. Please advise.
[2015-11-29 23:29:55] |
This is not supported when using the Volume by Price study on a TPO Profile Chart. We do not think we are going to get to supporting this until sometime in January. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
