Date/Time: Wed, 25 Dec 2024 18:20:04 +0000
How do I change the Candlestick outline colors using ASCIL code
View Count: 1897
[2015-11-28 21:41:12] |
KhaosTrader - Posts: 128 |
Hello, How can I programatically change the candlestick outline color as an indicator for my study? When certain conditions are met, I want to change the outline of the candle, yet keep the fill color constant according to normal candlestick coloring rules. Thank you in advance. |
[2015-11-30 08:10:39] |
This is all documented here: https://www.sierrachart.com/index.php?page=doc/doc_GraphDrawTypesColorSettings.php#ACSILColorControlOfPriceBarGraphDrawTypes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-30 08:15:27] |
Actually disregard the documentation in the prior link we gave. We misunderstood initially what you wanted. You just need to use the Subgraph Draw Style: DRAWSTYLE_COLORBARHOLLOW. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_scSubgraph.html#scSubgraphDrawStyle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-30 08:16:21
