Date/Time: Sat, 23 Nov 2024 05:18:08 +0000
Open orders and cancellation update problem
View Count: 1352
[2013-06-20 19:18:47] |
RQ - Posts: 50 |
I don't know what has happened but after the update the following is not working. Let's say I have an open short trade with 10 lots with bracket orders included on the chart. Then I decide to take five lots of; I normally just set the quality and hit the buy at market button. This would automatically buy five lots and change the quality in the two bracket orders to 5 lots. But this afternoon after update it simply put in a new order accompanied with new brackets. It's so long since I have been working with this setting I have forgotten. Please point me in the right direction. |
[2013-06-20 19:32:09] |
You need to enable Scale Out: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#ScalingOut Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
