DTC Protocol Discussion Forum
Date/Time: Tue, 04 Nov 2025 15:43:11 +0000
LogonRequest::TradeMode value when SC is server
View Count: 2860
[2015-11-27 17:22:07]
onnb - Posts: 664
When SC is a server does it use this value or ignore it?
[2015-11-27 22:08:00]
DTC Engineering - Posts: 320
Yes it does use this value and simulated trading is supported in version 1330.
In Sierra Chart, both Demo and Simulated Trade Modes are considered the same and are treated as simulated trading.
[2015-11-27 22:25:55]
onnb - Posts: 664
Ok, so what if there is a mismatch between how SC is running and the client that connects.
For example:
1. SC has trade simulation mode on and I send in "live"
2. SC is connected to a Transact live-live trading account and I send in Sim or Demo
Does this make sense? What is expected behavior by DTC/Server in these cases?
Date Time Of Last Edit: 2015-11-27 22:26:06
[2015-11-27 22:36:21]
1. Submitting an order under this condition will result in it being rejected.
2. Submitting an order under this condition will result in it being rejected, assuming Trade Simulation Mode is not enabled in Sierra Chart.
Yes this does make sense because the DTC protocol server in Sierra Chart will never be allowed to override the manually set "Trade >> Trade Simulation Mode" setting.
Date Time Of Last Edit: 2015-11-27 22:37:13
