Date/Time: Wed, 25 Dec 2024 15:50:07 +0000
CBOT Mini Grains Continuous contract issues
View Count: 717
[2015-11-26 16:37:18] |
User346632 - Posts: 1 |
Hi there, For some reason I can't get continuous back-adjusted data for mini-sized grains of CBOTM (XK, XN, XW); it works for regular grain markets, but when I request continuous, back-adjusted data for minis, nothing happens. See screenshot enclosed http://www.sierrachart.com/image.php?l=1448555796228.png |
[2015-11-26 22:34:10] |
Rollover rules have now been defined for these futures symbols. Update Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps After this is done, go to the chart and select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-26 22:34:39
