Date/Time: Wed, 25 Dec 2024 15:42:21 +0000
Exception handling disabled
View Count: 1235
[2015-11-26 08:13:51]
User96015 - Posts: 55
Dear sir.
I' m building a new study that include TRY-CATCH in c++ code.
But while I' m compiling it I replay an error:
error: exception handling disabled, use -fexceptions to enable
Do you know how can I enable -fexceptions?
Thanks and bye.
[2015-11-26 09:10:53]
Refer to step 19.8 here:
https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html#StepByStepInstructions
It explains that you can put these in the Additional Compiler Parameters text box. Let us know if you need more help. So you should just be able to put -fexceptions in that box.
Date Time Of Last Edit: 2015-11-26 09:12:33
