Date/Time: Sat, 23 Nov 2024 04:58:36 +0000
Lost F5 & F6 functions
View Count: 1649
[2013-06-20 16:22:31] |
RPinCAR - Posts: 27 |
How do I reset my F-keys functions? Thanks, Ron |
[2013-06-20 16:29:30] |
Please refer to the documentation for this here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSettingsMenu.html#CustomizeKeyboardShortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-20 16:38:00] |
Nope, didn't work. I reset everything to default-no change/work. I then reassign F5 to Chart settings-no change/work. I'm sure I have screwed something up. I'll shut down and reopen. |
[2013-06-20 16:39:06] |
Rebooting SC worked....
