Date/Time: Wed, 25 Dec 2024 16:16:25 +0000
DOM Scale Settings Range
View Count: 782
[2015-11-25 17:44:10] |
User842703 - Posts: 55 |
Under Scale settings I have set range to 47 however when moving to another symbol or shutting down it always reverts back to the standard 56. Is there a way to save this range?
[2015-11-25 18:36:16] |
When changing the symbol it will reset. However, not when restarting Sierra Chart as long as you have saved your charts and other windows as a Chartbook. We have verified that. Are you saving the charts as a Chartbook and opening that Chartbook? Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html There should not be any problem with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-25 19:15:54] |
Its actually a separate DOM not one attached to a chart and when exiting I just Save All. Having just exited/restarted again, the settings have saved so I must have also changed symbol previously. Assume there is no work around to keep the settings when changing symbol. |
