Date/Time: Wed, 25 Dec 2024 16:18:14 +0000
Changing Global Type Text Color in version 1269
View Count: 826
[2015-11-25 17:35:31] |
User47706 - Posts: 22 |
Hello folks, I cannot seem to change the color of the text that I type on charts. It is defaulted to green. I have tried and failed in Global Settings>>Graphics Settings>>Chart Text. Should I be able to change the text color in my current service package of 1? |
[2015-11-25 18:00:00] |
You need to do this through the Drawing Tool Configuration window for the Type Text tool. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DrawingToolConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-25 18:29:30] |
Thank you. My next question is how might I best repository blocks of text for reuse? If I want to have, say, "Entry Focus Timeframe" stored so that I can quickly recall and place it on a chart. |
[2015-11-26 05:54:32] |
Refer to Custom Text Drawing ToolBar Buttons: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CustomTextDrawingToolBarButtons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
