Date/Time: Wed, 25 Dec 2024 15:52:07 +0000
ACSIL - Detect remote instance disconnect/connect
View Count: 962
[2015-11-25 11:52:06]
ejtrader - Posts: 688
SC Team - I use 2 instances of SC. First instance(remote) use only for data feed and second(local) instance for chart/study calculations.
Is there any way to detect remote feed connect/disconnect status from local instance - in a reliable way?
The reason - I have a study based on the scid/T&S combination - works fine in all conditions except I have to recalculate the study(insert key) if remote instance data feed disconnect/connected ( potentially due to T&S records/Sequence - have a gap - when this happens). Trying to see if there is any reliable way to detect remote instance connect/disconnect state to force recalculation from local study automatically.
Date Time Of Last Edit: 2015-11-25 12:18:10
[2015-11-25 15:55:00]
Update: Found a workaround to this issue with in the study itself and good with this.
Though for information sake - would like to know if it is possible to detect the feed disconnect/connect state with local/remote instances.
