Date/Time: Wed, 25 Dec 2024 14:23:20 +0000
symbol $NSHF
View Count: 786
[2015-11-24 21:22:15]
User739935 - Posts: 37
I am not getting any data for this symbol.When I open chart setting window the "Date Range in File "is showing unknown to unknown.I have had no problem with this symbol before today.Have tried to delete chart and open a new one but it doesn,t work.
[2015-11-24 23:31:17]
We see you are using TransAct. That symbol has not been supported with TransAct for about two years now.
It is not the correct symbol. You need to use the market statistics symbols found in File >> Find Symbol. Refer to:
Sierra Chart Market Statistics: Symbols
Date Time Of Last Edit: 2015-11-24 23:31:32
