Date/Time: Wed, 25 Dec 2024 13:52:52 +0000
Do I need TWS open?
View Count: 867
[2015-11-24 19:45:36]
User638756 - Posts: 52
Do I need TWS (for interactive brokers) open if I want to use Sierra charts?
[2015-11-24 22:34:59]
If you will be using Sierra Chart with your Interactive Brokers account, you definitely need Interactive Brokers Trader Workstation open.
[2015-11-24 23:36:27]
User911705 - Posts: 89
Yes, above is correct.... unless you run the IB Gateway. If you run the Gateway as the interface to IB, you don't need big old clunky TWS running.
[2015-11-25 02:43:36]
Yes, you can also use the Interactive Brokers Gateway.
