Date/Time: Wed, 25 Dec 2024 14:40:24 +0000
CL position line disappears
View Count: 780
[2015-11-24 18:56:45] |
phaedonk - Posts: 352 |
This started a few days ago, when CL fills in TWS Sierra shows the position line for a few seconds and then it vanishes. It only happens with CL. What could be wrong? I'm on 1300. When this happens I cannot even flatten, as Sierra thinks I have no position. |
[2015-11-24 19:02:06] |
You should have received a notice about this when starting Sierra Chart, in the System Notification Message. It links to this: Notice: Important Update for Interactive Brokers Users | Post: 74190 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
