Date/Time: Wed, 25 Dec 2024 13:56:12 +0000
Programmatically adding studies to a chart
View Count: 775
[2015-11-24 17:44:50] |
jwick - Posts: 142 |
Two questions: 1. If it possibly to programmatically add a study to a chart (either onto the chart my study is on, or onto a completely different chart that my study has a reference to / has opened on its own)? 2. A less general version of the question above: Can I calculate the ATR on a chart my study has a reference to (but is not on directly) using the sc.ATR function? Thanks! |
[2015-11-24 17:50:44] |
1. No. 2. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
