Date/Time: Wed, 25 Dec 2024 14:23:20 +0000
Net change between bars not dispalying
View Count: 766
[2015-11-24 16:00:25] |
User77348 - Posts: 3 |
Its been a while since this went away. I used to be able to see in both "Chart Values for Last Display" and "Chart Values for Tools" windows it would show the net change since the last bar, or the bar that I had the cross hairs on. It will up on top display the change in the current bar where it up top My data feed is Rithmic and I am using Version 1307. I don't know if its that somehow I miss clicked something, something got corrupted or it is something that Rithmic doesn't do. http://www.sierrachart.com/image.php?l=1448380723483.png Attached is a pic of my desktop. So what do I do to get it back, or is it Rithmic? |
My windows.jpg / V - Attached On 2015-11-24 15:56:05 UTC - Size: 744.59 KB - 319 views |
[2015-11-24 17:45:24] |
This was unexpectedly removed for those Chart Values windows. The bar to bar Price Change will be added back to the next release.
