Date/Time: Fri, 25 Sep 2026 05:49:20 +0000
Referencing data using sc.GetExactMatchForSCDateTime
View Count: 1728
[2015-11-24 15:51:03]
wwwingman - Posts: 185
Hi
I am using sc.GetExactMatchForSCDateTime to reference data from other time frames.
It works *most* of the time. I would expect it work all the time. Maybe I missed something.
I use two charts, main is 5 mn, secondary is 1 mn. Same session time/loaded number of days etc. Data is IQFeed.
I use the main start date time to find the index of the secondary index.
On 10 days of ES globex session (~2700 bars) I have 12 mistakes, meaning the index is not found.
The data seems ok, and the mistakes don't seem to appear on special moments like start/end of day/session/whatever.
Here is core of the code:
  for ( int _barIndex = sc.UpdateStartIndex ; _barIndex < sc.ArraySize - 1 ; _barIndex++ )
    // Handle _barIndex bar
    SCDateTime   _startDateTime     = sc.BaseDateTimeIn[_barIndex];
    int     _proxyStartIndex   = sc.GetExactMatchForSCDateTime(_proxyChartNumber, _startDateTime);
    if( _proxyStartIndex == -1 )
      logMsg.Format("ERROR : date<%s> _proxyStartIndex<%d>", sc.FormatDateTime(sc.BaseDateTimeIn[_barIndex]).GetChars(), _proxyStartIndex);
      sc.AddMessageToLog(logMsg,0);
      continue;
Please advise.
-- W.
[2015-11-24 18:00:27]
What specifically is meant by?:
[2015-11-24 18:08:44]
What specifically is meant by?: It works *most* of the time.
It means, on rare occasions, the function returns a -1 error code.
It always happens on the same bars. But I do not see something specific in those bars.
I gave in the first message an example : on ES, 2700 bars, you have 12 missed calls. Thats 12/2700 or 4 calls per 1000 calls.
-- W
[2015-11-24 18:11:09]
The question is, is there actually an exact match where -1 is returned. We would not know without checking the bars where that occurred and we cannot do that.
Date Time Of Last Edit: 2015-11-24 19:03:10
[2015-11-24 18:15:40]
deleted.
Date Time Of Last Edit: 2015-11-24 18:16:24
[2015-11-24 18:32:09]
The question is, is an exact match found where -1 is returned.
sc.GetExactMatchForSCDateTime returns an exact match when it DOES NOT return -1.
FWIW : I made a simple loop, looking for a secondary index with an exact same date time start as the main chart bar index.
And it works 100% of the time. As I would expect.
Which means, for me, there is a problem with sc.GetExactMatchForSCDateTime, or a misunderstanding on my side.
With this code : 100% correct indexes.
    // compute secondary index (instead of sc.GetExactMatchForSCDateTime)
    int     _proxyStartIndex   = -1;
    for (int _i=0 ; _i < _proxyDateTimeData.GetArraySize() ; _i++)
      if ( _startDateTime == _proxyDateTimeData[_i] )
        _proxyStartIndex = _i;
        break;
      continue;
[2015-11-24 19:08:12]
What we meant is there actually an exact match where -1 is returned? As we said, this is the question we cannot answer.
Here is the actual code:
int GetExactMatchForSCDateTime(int ChartNumber, const SCDateTime& DateTime)
    int Index = GetContainingIndexForSCDateTime(ChartNumber, DateTime);
    SCDateTimeArray ChartDateTimeArray;
    GetChartDateTimeArray(ChartNumber, ChartDateTimeArray);
    if (ChartDateTimeArray[Index] == DateTime)
      return Index;
    else
      return -1;
Date Time Of Last Edit: 2015-11-25 05:56:47
[2015-11-24 22:32:45]
OK. Thank you for your help.
I have no more questions.
For the record, and other programmers, here is what I finally understood :
1. There was a bug on my side. It led to wrong results on the loop I indicated above and on the sc.GetExactMatchForSCDateTime.
2. sc.GetExactMatchForSCDateTime WILL GIVE 100% matches IF you set the "Include Columns with no data" on both charts.
The problem is that on very low activity we may have missing bars. This option will force us to have all the 5 mn bars and all the 1 mn bars. All the 5 mn bars will have a matching 1 mn bar index.
3. Having the "include columns with no data" option will not solve the problem of mixing charts of different nature like 5 mn + renko charts. Using GetContainingIndexForSCDateTime seem to be the only solution.
-- W.
