Date/Time: Wed, 25 Dec 2024 14:35:42 +0000
Zig Zag display length
View Count: 1191
[2015-11-24 15:01:14]
User303704 - Posts: 9
I am using Calculation Mode 2 and Number of Bars Required for Reversal = 4
I would like to measure the size of the swings. As you can see from the example in the rectangle of the screenshot attached...how do I get the Zig Zag to measure from the bottom wick of the red candle to the top wick of the last green candle?
imageZig Zag.JPG / V - Attached On 2015-11-24 15:00:52 UTC - Size: 79.26 KB - 342 views
[2015-11-24 18:09:40]
Not sure we fully understand this. So it looks like at the last bar the zig zag line does not go to the high. Not totally sure why but it would most likely be because you are using Renko chart bars.
