Date/Time: Wed, 25 Dec 2024 14:25:48 +0000
in a quotespreadsheet PreviousClose not correct
View Count: 720
[2015-11-24 13:48:36] |
User825944 - Posts: 5 |
Hallo support team, previousClose and SettlementPrice are equal. that is false. Can you make this right? Thank you |
SC_team.png / V - Attached On 2015-11-24 13:47:22 UTC - Size: 16.57 KB - 249 views |
[2015-11-24 17:58:53] |
In Sierra Chart those two values will be the same.
