Date/Time: Wed, 25 Dec 2024 14:35:14 +0000
Support Reversals
View Count: 871
[2015-11-24 06:00:01]
User713273 - Posts: 409
The default value for the SupportReversals variable is FALSE (No). If this variable is set to TRUE (Yes), then reversals are supported. A reversal is triggered when a Buy Entry or Sell Entry order is submitted and an actual opposite Trade Position currently exists for the symbol.
The above literature is from the SC documentation. My question, say I wanted to support a reversal with a different symbol other than the current trade symbol, would utilizing ACSIL be the format to use or is there a better variable to utilize?
[2015-11-24 08:23:15]
If you are referring to trading a different Symbol than the main symbol of the chart, then SupportReversals does not apply. You would have to implement your own logic completely for that.
