Date/Time: Wed, 25 Dec 2024 14:02:47 +0000
FIX FXCM Sim show zeros at Trade Activity Log
View Count: 790
[2015-11-23 20:32:35] |
User368248 - Posts: 46 |
Hello. Please refer to attached images I dont see the profit/loss on each trade, just zero positive or zero negative. How can I resolv this? Is it a configuration of my terminal ? I am using 10k as quantity for send trades. The trade window show me some values ( I this are correct ones ), check images : Thanks in advance! |
FixFxcm1.png / V - Attached On 2015-11-23 20:32:10 UTC - Size: 42.28 KB - 296 views FixFxcm2.png / V - Attached On 2015-11-23 20:32:18 UTC - Size: 51.7 KB - 302 views |
[2015-11-23 22:20:31] |
The Order Quantity is too low for the particular trade you are showing in the Trade Activity Log. The quantity certainly was not 10000 for those. It is clearly 1 as shown. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/helpdetails77.html#OrderQuantityEffectOnPLValuesForForex Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-23 22:21:59
[2015-11-24 05:59:20] |
Thanks!
