Date/Time: Wed, 25 Dec 2024 07:05:38 +0000
Back up
View Count: 700
[2015-11-23 09:20:15] |
User868662 - Posts: 9 |
Dear Customer support, If i want to take a backup of a chart to transfer it to another computer *.cht is the only file i have to take a backup or do i have to take any other back up file as well? In the new computer with SC loaded i should be able restore the .cht file and start working immediately with indicators,templates all loaded for this particular layout/file. Thanks, Selva |
[2015-11-23 09:48:34] |
If you just want to copy a Chartbook, then you just need to transfer the Chartbook file. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#CopyChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
