Date/Time: Wed, 25 Dec 2024 06:54:17 +0000
tpo value area study mondays
View Count: 727
[2015-11-21 20:25:21] |
jim branch - Posts: 23 |
I am having a problem with the TPO value area line study, when using esz15 GLOBEX session. there is market data after Fridays close.(16:30 to 17:00) Mondays levels are plotting this 30 minute data only. Is there a way to delete Friday s after hours data so that Mondays levels would reflect Fridays session? (16:30 thursday-16:15 friday eastern) Date Time Of Last Edit: 2015-11-21 23:56:25
[2015-11-22 01:57:27] |
Update Sierra Chart to the latest release with Help >> Download Current Version. After the update, set the Session Times to: 16:30:00 16:15:00 Select Chart >> Chart Settings and uncheck Load Weekend Data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
