Date/Time: Wed, 25 Dec 2024 14:11:42 +0000
trans fill rect to zero
View Count: 778
[2015-11-21 05:21:26] |
umair1 - Posts: 86 |
Hi, I see that you have a "Trans Fill to Zero" draw style. Can you also add a "Trans Fill Rect to Zero" drawstyle? Thanks |
[2015-11-23 19:57:35] |
We will add this.
