Date/Time: Wed, 25 Dec 2024 06:11:37 +0000
Message Log Fix Message
View Count: 797
[2015-11-20 21:34:27] |
User307319 - Posts: 41 |
Dear Sierra, i received thsi message today, during the market open - could you, please, advise whats happened. Software version: 1324 | 2015-11-20 11:34:37 Real-time Intraday chart data file updates started for ES-201512-CME | 2015-11-20 11:34:46 TT FIX Trading: Received a FIX message missing required field SenderCompID <49>. | 2015-11-20 15:34:36 * FIX Message: 8=FIX.4.29=0004535=UAP34=49152=20151120-20:34:36.767146=010=061 | 2015-11-20 15:34:36 * TT FIX Trading: Received a FIX message missing required field TargetCompID <56>. | 2015-11-20 15:34:36 * FIX Message: 8=FIX.4.29=0004535=UAP34=49152=20151120-20:34:36.767146=010=061 | 2015-11-20 15:34:36 * TT FIX Trading: Error in received Position Report <UAP> message. Failed to get the value for the PosReqID <16710> field. Field not found. | 2015-11-20 15:34:36 FIX Message: 8=FIX.4.29=0004535=UAP34=49152=20151120-20:34:36.767146=010=061 | 2015-11-20 15:34:36 |
[2015-11-21 04:22:28] |
You can disregard these. Refer to: http://www.sierrachart.com/index.php?page=doc/TradingTechnologies.php#CommonErrorMessages Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-21 04:22:50
