Date/Time: Wed, 25 Dec 2024 07:14:25 +0000
Second Instance dont appear when I try insert symbol..
View Count: 681
[2015-11-20 18:26:53]
User368248 - Posts: 46
Hello.
If I open a study ( for example spread ) its works selecting symbol for second instance.
But If I try to find and insert a symbol from new quote spreadsheet then only show in grey color the first instance (current) and not the secon one.
Can you help me please to resolv this ?
[2015-11-20 20:27:08]
It is not possible to use data from remote instances of Sierra Chart in Quote Spreadsheets or Quote Boards.
However, we see you are using Rithmic and FXCM. It is possible in the instance connected to Rithmic, that you can use Forex/CFD symbols just by selecting them from the Find Symbol >> Forex/CFD list.
