Date/Time: Wed, 25 Dec 2024 06:57:57 +0000
I want to set up a structure similar to the VolumePerPrice structure ...
View Count: 814
[2015-11-20 15:25:36]
marcovth - Posts: 61
Hello ...
I want to set up a structure similar to the VolumePerPrice (s_VolumeAtPriceV2) structure.
So, I would like to calculate some values and store it per bar and per price level, similar to the Ask and Bid volumes stored at a price inside a single bar.
Is there a good example available?
I tried to use arrays, but that didn't out very well.
Thanks in advance.
[2015-11-21 01:32:22]
You can just use the s_VolumeAtPriceV2 data structure included in VAPContainer.h
Create it using the C++ new operator.
It is undocumented though. It is not something we have any time to document. But you may be able to figure it out looking at some of the ACSIL examples which do use it.
