Date/Time: Wed, 25 Dec 2024 06:41:23 +0000
open an imported intraday file
View Count: 735
[2015-11-20 14:55:20]
User352506 - Posts: 6
I exported the intraday date file YMZ4 in SC last year . I didn't change the file. Now I'm trying to open the file , but it doesn't work. I did the following steps:
Edit --> import and load intray data --> i choose the Folder on my hardrive where i saved the file --> Mouseclick on the file YMZ4.txt
SC then opens automatically the Chart for YMZ5. To solve the issue I tried the following:
In Chart Settingss window in the field symbol i typed in YMZ4 and and "use data range" from 2014-10-01 to 2014-11-01. After this the chart window is blank. Unchecking "Automatically rollover ..." also doesn't solve the issue.
What I am doing wrong?
[2015-11-21 04:41:21]
As the documentation explains here, you need to place the file you are importing in the Sierra Chart Data Files Folder:
http://www.sierrachart.com/index.php?page=doc/doc_ImportExport.html#ImportLoadIntradayData
