Date/Time: Wed, 25 Dec 2024 05:06:44 +0000
trigger on fill
View Count: 684
[2015-11-20 00:54:53] |
User799916 - Posts: 3 |
ok so i have a open order when this is filled how can i trigger to open another order?
[2015-11-20 02:08:47] |
The closest that is available to this would be Attached Orders: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
