Date/Time: Mon, 21 Apr 2025 04:35:52 +0000
compact tool values window background and text color
View Count: 1427
[2015-11-19 20:54:11] |
User411334 - Posts: 38 |
Hello support. Is it possible to change compact tool values window background and text color independently from chart global settings? Thanks.
[2015-11-20 02:11:15] |
Yes this can be done by changing the Graphics Settings for an individual chart. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html Specifically you will want to change the Chart Text and Background colors. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-20 09:51:34] |
The thing is that i don't want to change background color of the chart, i just want to change background color of the compact tool values window itself. I suppose there is no way to do this for now without changing background chart settings right?
[2015-11-20 17:03:30] |
Yes this is a correct understanding.
[2025-03-07 04:12:52] |
ROI+ - Posts: 10 |
Is this still true? No way to change the text color in the Compact Tool Values Window? The fourth column is a maroon text that's very difficult to see on a black background.
[2025-03-07 07:38:33] |
Sierra_Chart Engineering - Posts: 19285 |
Yes these colors are controllable. Refer to: Graphics Settings: Introduction The color is: Chart Values Window Default Text Color And the color you see now would be a color that you have set. That is not the default color that you are currently seeing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-07 07:39:35
