Date/Time: Sat, 23 Nov 2024 04:47:36 +0000
[User Discussion] - Spreadsheet Study Question
View Count: 1531
[2013-06-20 07:03:53]
tobi - Posts: 351
I'm using a spreadsheet study in a chartbook where I'm trading the EUR/USD.
Now I want to use this chartbook setup for other FX symbols too.
A) Do you recommend using one spreadsheet (e.g. FX) for all chartbooks, with different sheet numbers for each symbol?
or
B) Do you recommend using different spreadsheets (e.g. EUR, GBP, CHF ...) for each symbol/chartbook?
or
C) Doesn't it matter if A) or B) is chosen?
[2013-06-20 07:17:58]
tobi - Posts: 351
Why do you label this a User Discussion?
Isn't there a recommendation from SC?
Does that mean, that from the software viewpoint C) is the case?
[2013-06-20 16:03:09]
Either way is fine. This is a decision for you to make.
[2013-06-20 16:16:48]
Sawtooth - Posts: 4118
My recommendation is to use the same-named spreadsheet within a chartbook (where each chart will appear on its own sheet/tab), and to use a unique-named spreadsheet for each chartbook. If you use the same-named spreadsheet concurrently across chartbooks, a recalc loop can begin.
