Date/Time: Wed, 25 Dec 2024 05:42:54 +0000
Scroll Multiplier
View Count: 1086
[2015-11-19 10:40:39] |
User842703 - Posts: 55 |
On an attached chart the mouse wheel scroll moves 1 bar each turn however on detached charts it moves 2 bars. I have Global Settings>General Settings2 Multiplier set to 1.00 and have just installed v1325. Is this a bug or another setting that needs to be changed?
[2015-11-19 16:35:10] |
Whether a chart is detached or not it will not make any difference. It could not be any kind of bug. It must be a system specific issue. We cannot duplicate the problem and this is something we cannot provide further help with.
