Date/Time: Wed, 25 Dec 2024 13:49:22 +0000
[User Discussion] - Graph 10% of the original last price
View Count: 1388
[2015-11-18 21:44:30] |
User702376 - Posts: 5 |
I would like to find a way to get the current last price to be 10% of the original last price and continue to graph the last price with candlestick bars. Example: Using symbol - NVOL-NYSE I would like for the chart to output a candlestick bar with only 10% of the original last price. I was able to get a line chart, using the above example but not a candlestick bar. I created a chart and added study subgraph multiply. Under settings>subgraphs tab, the Graph Draw field is greyed out. Please advise. Thanks |
[2015-11-20 12:37:33] |
If I have stated something incorrectly, please advise. Thanks |
[2015-11-24 00:26:17] |
Bump
[2015-11-24 01:57:37] |
Sawtooth - Posts: 4142 |
You can do this with the Spreadsheet Study study: -Set Chart Region to 1 -Check 'Display as Main Price Graph' (Uncheck it to see a comparison) -Set 'Use Price Graph Style to Yes -Give it a name in the Spreadsheet Name field -Use formulas like these in row 3 of columns K,L,M,N: =B3*0.1 =C3*0.1 =D3*0.1 =E3*0.1 Here's the documentation: http://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudyInputs.html#PriceGraphStyle Date Time Of Last Edit: 2015-11-24 01:58:59
