Date/Time: Wed, 25 Dec 2024 05:13:53 +0000
Transfer a string from ACSIL to a spreadsheet study
View Count: 804
[2015-11-18 13:00:59] |
Marmany - Posts: 307 |
Is it possible to transfer a string constant from an ACSIL study on a chart to a spreadsheet study on another chart? At present I convert the string to an integer, store in an sc.subgraph, pick up the subgraph on the spreadsheet study then decode the integer back to the string within the spreadsheet. This seems an inefficient way of working but been through the SC Document and not able to find an alternative. Please advise if there is a more efficient way Many thanks |
[2015-11-18 18:13:06] |
No, this is not supported. The way you are doing it is the most reasonable way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
