Date/Time: Thu, 01 Oct 2026 07:33:35 +0000
Installed 1325--Lost Chart Header, Title Bar hides by unchecking but doesn't come back
View Count: 1144
| [2015-11-18 00:30:43] |
| wynmill - Posts: 28 |
LostLogitech Marble Mouse controls of two programmed keys--possibly from hotkeys are ctrl(or whatever) minus----where before they were ctrl + but not sure.
| [2015-11-18 03:14:59] |
Are you referring to the title bar of the main Sierra Chart window? Or to a detached chart? Could you attach a screenshot showing what you are referring to. Here are instructions: Support Board Posting Information: Attaching a File (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-11-18 15:11:55] |
Main Sierra Chyart Wiundow Gloobal Settings, Chart header dictates what you want on the header. Whatever you call it, it's not the title bar(that'sw the details of price action inside the chart at top left). That disappears on uncheck and doesn't come back. The chart header is just below tthe File-Help menu and shows whatever you have decided on in chart header with crosshair activation. So you can use crosshair two months ago and quickly get chart header info Fixed Logitech hotkey problem Still trying to get chart header in main header. Clicked on Toolbar 2 and it installed in area want chart header. 1st, thought I oinly poaid for one toolbar not two. 2nd, how do I get rid of it??????????????????? Date Time Of Last Edit: 2015-11-18 15:49:46
| [2015-11-18 17:15:17] |
It sounds like you are referring to the old status bar. Here are instructions for the new replacement for it: New Control Bar to replace ToolBar and Status Bar | Post: 66601 To remove a ToolBar select Window >> Toolbars >> ToolBar # of the ToolBar that you want to remove. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-01-20 13:04:33] |
i GUESS I am using compact tool value window now for old statuis bar. Mine varies from two lines to 12-14 and I havent figured out how to 1. Get it uniform on all charts. 2. Then get it to show HLC only. So, how do I do that? |
| [2016-01-20 18:42:56] |
All of this is explained in this section here: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
