Date/Time: Wed, 25 Dec 2024 05:43:16 +0000
no symbol for liffe 10-Year Long Gilt
View Count: 877
[2015-11-18 00:04:29] |
User488718 - Posts: 10 |
hi, can u pls add in the symbol list the liffe 10-Year Long Gilt? my broker is interactivebrokers and i have delayed feed. thanx |
[2015-11-18 08:54:15] |
What is the symbol you use for this market within Interactive Brokers Trader Workstation? That will help us to find it more easily.
[2015-11-18 11:07:52] |
Symbol: R Description/Name Long Gilt Exchange ICEEU Contract Type Futures Country/Region GB United Kingdom Currency British Pound (GBP) Contract Identifiers Conid 198627627 |
[2015-11-19 02:58:56] |
This market has now been added. Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps After that you will see it in File >> Find Symbol. Let us know if there any problems. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-19 08:45:56] |
daily chart looks correct. but for some reason, intraday chart has wrong pricing, 1.17 last price vs 116.46 (that is shown correctly on daily chart) ... basically in intraday chart the pricing gets divided by 100 and then rounded up. see below. http://www.sierrachart.com/image.php?l=1447921369609.png |
[2015-11-19 09:20:20] |
There was a multiplier setting which was not set correctly. This has now been corrected. Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps After that is done, re-download the data in the chart with Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-19 09:22:05
