Date/Time: Wed, 25 Dec 2024 04:18:07 +0000
TWO COMPUTERS
View Count: 740
[2015-11-17 10:16:52] |
User82615 - Posts: 106 |
HELLO I WANTED TO ASK YOU IF IT WOULD BE POSSIBLE TO WORK WITH TWO DIFFERENT COMPUTERS AND WITH ONE ACCOUNT OF SIERRA CHARTS AT THE SAME TIME IN BOTH COMPUTERS , OR IF TO DO THAT IT WOULD BE NECCESARY TO HAVE TWO DIFFERENT ACCOUTS OF SIERRA CHARTS. THANK YOU VERY MUCH |
[2015-11-17 10:26:02] |
This is supported. Refer to this section here: Sierra Chart Purchase and License Information: Licensing / Number of Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
