Date/Time: Wed, 25 Dec 2024 04:56:00 +0000
Can I remove the green bar from a detached chart?
View Count: 754
[2015-11-16 21:06:58] |
infpz - Posts: 826 |
See image please.
[2015-11-16 22:47:28] |
This is very very unusual. Is this from your copy of Sierra Chart or another user? The first thing we recommend is to restart Sierra Chart and reduce the number of programs running on the system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-16 22:48:26] |
It is from another user.
[2015-11-16 23:01:16] |
OK please provide them the information we gave. Either there is some problem within Sierra Chart, that we do not know about, which is very unlikely, or they have too many programs on their system running which can cause this kind of problem sometimes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
