Date/Time: Wed, 25 Dec 2024 04:25:00 +0000
ACSIL - Drawing a DRAWING_ELLIPSEHIGHLIGHT just on one side of Numbers Bars
View Count: 869
[2015-11-16 13:59:04]
Zosimus - Posts: 345
Is it possible to draw a DRAWING_ELLIPSEHIGHLIGHT just on the Bid numbers or just on the Ask numbers of Numbers bars ?
The drawings have to be attached to specific bars so I cannot use Relative values.
At the moment If I use the same Index value for the Tool.BeginIndex and the Tool.EndIndex I get a small circle in the middle of the Numbers bar and If I use a different Index value for the Tool.BeginIndex and the Tool.EndIndex then the Elpise extends to other bars.
I am looking for an option to draw a circle or ellipse Just on the Bid side or just on the Ask side (at a specific price level).
[2015-11-16 17:29:05]
This is not supported, and is not something we can easily add support for.
Inherently with the way that Chart Drawings are designed this is just not supported.
