Date/Time: Wed, 25 Dec 2024 04:29:16 +0000
long-term user discount
View Count: 743
[2015-11-16 09:37:02] |
User523790 - Posts: 3 |
Hello, at the moment I am entitled to 30% discount for long-term usage but if I buy now package 5 for 1 month just to try it, will I still have that 30% discount after that 1 month for next purchase? I do not simply know how the discount is calculated, whether it is based on all purchases in past, or for example on last three purchases. Thank you. Date Time Of Last Edit: 2015-11-16 09:38:12
[2015-11-16 09:50:18] |
Yes you will have the 30% discount now and for any subsequent payments. It is based upon all payments in the past. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-16 14:10:29] |
Thank you very much!
