Date/Time: Wed, 25 Dec 2024 04:52:38 +0000
Point and Figure / X and O / high to width ratio to 1
View Count: 783
[2015-11-16 08:04:33] |
User84094 - Posts: 47 |
How to get price X and O high to width ratio to 1 ? Like in picture "1 to 1" I get the X and O-s too wide or to narrow. |
1 to 1.png / V - Attached On 2015-11-16 08:03:55 UTC - Size: 31.51 KB - 322 views |
[2015-11-17 10:54:14] |
We will prepare formal documentation for this. But basically the X and O boxes in the columns are sized to fit the chart window based upon the spacing between the chart bars and the range of prices from the top of the scale to the bottom of the scale. So therefore you need to change the spacing between the chart bars and the range of prices in order to get the appearance as you require. Personally, we think this concept of X's and O's is a very old outdated concept meant for graph paper and just using ordinary chart bars is more practical. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-17 22:07:22] |
Here is the formal documentation on this subject: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#ScalingPointAndFigureChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
