Date/Time: Wed, 25 Dec 2024 05:00:46 +0000
Pricing question when using Sierra Chart with Rithmic Data from AMP Futures
View Count: 3552
[2015-11-14 07:28:20] |
User223429 - Posts: 13 |
I asked the AMP futures and they said the Sierra chart package 5 costs 25 USD deducted directly from AMP account for using Sierra with CQG or Rithmic Data. Is that correct? I have just registered a Rithmic demo account and wanna test it with Sierra Chart. I got a Sierra Chart account and used the free trial before. So If i wanna use Rithmic demo account now, I need to re-new Sierra Chart subscription first or AMP futures has a specific version of Sierra Chart? When I trade live with AMP futures Rithmic feed later, where should I pay the Sierra Chart monthly fee (AMP account or with from Sierra site)? |
[2015-11-14 18:44:52] |
We cannot comment on pricing from a reseller or affiliate as they are responsible for that. Sierra Chart pricing can be found here: Description of Service Packages and Pricing We see your Sierra Chart account is currently active at service package 3 so you can use any service with it including Rithmic. Here are the Rithmic set up instructions: http://www.sierrachart.com/index.php?page=doc/Rithmic.php#SetupInstructions There is no specific version for Rithmic. Let us know if you need more help. ----- 1. To purchase usage time, select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/usercp.php?page=SCUsageTimePayments Login with your Sierra Chart Account Name and Password. 2. Choose the number Months you wish to pay for and the Service Package. 3. Choose one of the payment options. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-11-16 03:28:47] |
So I pay for the software from AMP account or from Sierra account? just want to avoid double payment here.
[2015-11-16 22:52:48] |
Either way. This is up to you. If you pay direct to Sierra Chart, make sure you are not billed from your broker.
