Date/Time: Wed, 25 Dec 2024 02:27:22 +0000
Data feed issue
View Count: 722
[2015-11-14 02:17:52]
User515532 - Posts: 19
I am located in Singapore and the market profile foot print(FP-2.png) is different from my friend(located in central america) who is getting the same feed.
My foot print does not have the zero print.
Please assist.
Thanks.
imageFP-1.JPG / V - Attached On 2015-11-14 02:10:01 UTC - Size: 85 KB - 298 views
imageFP-2.PNG / V - Attached On 2015-11-14 02:10:15 UTC - Size: 46.6 KB - 274 views
[2015-11-14 04:01:31]
1. We see you are using the Sierra Chart Exchange Data Feed. We also see you are using Numbers Bars.
You can be assured that the Sierra Chart Exchange Data Feed is delivering nearly 100% accurate data.
When using Numbers Bars make sure you have a Tick by Tick data configuration as explained here:
http://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php
As long as you have a tick by tick data configuration and you are using the SC Exchange Data Feed you can be assured of nearly 100% accuracy.
We also see that you are using TransAct or OEC based upon the screenshot. And that you have activated the 94.50 USD/month CME exchange fee. You only need the 3.25 USD per month exchange fee when using one of those trading services.
You can cancel and activate exchanges here:
https://www.sierrachart.com/usercp.php?page=SC_RealTime_DataFeed_SetExchanges
You will save a lot.
Date Time Of Last Edit: 2015-11-14 04:02:55
