Date/Time: Wed, 25 Dec 2024 01:40:02 +0000
ATR study shows only zero value on the right margin/Y-Axis
View Count: 808
[2015-11-13 15:20:50] |
User192509 - Posts: 12 |
Dear Support, Per the attached PDF screenshot, the ATR study on the tick chart shown doesn't show a value on the right margin/Y-Axis other than zero. What am I doing wrong please? Maybe ATR doesn't work for tick charts? Thank you! William |
Friday, November 13, 2015.pdf - Attached On 2015-11-13 15:17:23 UTC - Size: 388.22 KB - 376 views |
[2015-11-13 18:17:05] |
You need to increase the number of decimal places for that study by following the instructions here: Changing the Price/Value Display Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
