Date/Time: Wed, 25 Dec 2024 15:41:31 +0000
DOM
View Count: 1498
[2015-11-13 14:26:14] |
User85698 - Posts: 12 |
Good day, Is there a functionality on the DOM to enable notes to be written inline with price ? Please see example attached Regards Dean |
DOM_NOTES.png / V - Attached On 2015-11-13 14:25:49 UTC - Size: 273.97 KB - 372 views Attachment Deleted. |
[2015-11-16 06:22:04] |
Good day I am able to copy chart drawings from another chart into the dom and thereby referencing key levels. However I would like to now make a note at those key levels. It would be really helpful if you added a function on horizontal ray / line to add text on the right side. Regards Dean |
[2015-11-16 09:43:08] |
This can be done. Follow the instructions here for this: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ModifyText Although we see a problem with the background coloring for the text on the Trade DOM and we will look into how to solve that. Although it should be fine for the time being until it can be improved upon. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-16 09:43:22
[2015-11-26 16:17:38] |
User399560 - Posts: 2 |
Hi, Following on from the above, is there the ability to move the Volume profile study to the right side of the DOM? I know you can arrange the bid, ask columns etc in any order you want and it would be great if this can be done with the VP study. Regards Luke |
[2015-11-27 18:07:25] |
There is an option to right align the Volume Profile. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#Settings However, this is not going to move it to the far right of the Trade Ladder window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
