Date/Time: Wed, 25 Dec 2024 04:38:18 +0000
new version 1322
View Count: 984
[2015-11-13 14:18:03]
inverter - Posts: 42
in this version appeared trade activity log -trade state for charts..puno same graph ... because I have more chart a different frame in one chartbook.kako to turn out to be as before. Photo attached.
mean daily and multiday result shows me lots of times as much as the open graph ... that I want to be the only one as before version ... how to solve? thanks
imagemore same result.png / V - Attached On 2015-11-13 14:17:47 UTC - Size: 13.93 KB - 329 views
[2015-11-13 18:27:34]
We understand the problem you are referring to. We are going to correct this today to remove the repeated Trade Stats for Charts lines for the same Symbol and Trade Account.
[2015-11-14 06:57:44]
ok,thanks ,will be in the new version removed the problem?
[2015-11-14 09:18:07]
Yes
[2015-11-14 19:31:40]
ok,thanks
[2015-11-14 23:52:08]
This is now solved. Update to the latest prerelease with Help >> Download Prerelease.
[2015-11-16 18:43:55]
ok,thanks
