Date/Time: Wed, 25 Dec 2024 02:13:17 +0000
Differentiating sound Alerts
View Count: 824
[2015-11-13 09:45:24]
nepher - Posts: 56
Hello Support,
In my Charts I have 3 types of settings for my alarms : Very important type1/Very important type2/very important type3 ; depending of the state of the market I would like to preferentialy sound type 1 with/or type2 /type3 alarms ; for the moment to do that easily it's not possible because the "Global Settings" Menu only offers the possibilty to mute all the sound alarms altogether (one sound channel).
Is it possible to adress for each sound Alarm the channel we would like it will sound ?
For instance In the Alert settings, for each Alert we shall have the possibility to check three boxes
Sound Alert 01 : sound channel1 =1,sound channel2 =0,sound channel3 =0
Sound Alert 02 : sound channel1 =0,sound channel2 =1,sound channel3 =0
Sound Alert 25 : sound channel1 =0,sound channel2 =1,sound channel3 =1
etc
And we shall have in the 'Global settings' Menu 3 independant lines for muting the sound alarms (Muting Alert sounds Channel1/Channel2/Channel3) instead of one only.
This could be very practical for me and perhaps for others to accurately monitor multiple markets together.
Thank you for your attention
Date Time Of Last Edit: 2015-11-13 09:49:53
[2015-11-13 18:28:49]
You will have to custom program your own solution:
https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html
